NAT redundancy on 6500
I can see it is easy to configure IP NAT redundancy on 3700, 7000 series devices, but how do I configure it on a 6500 series switch ??
The other systems basic command is  ip nat inside source static 1.1.1.1 .2.2.2.2  redundancy hsrp1  then you associate this with the standby interface.
This last entry cannot be entered on the 6500 ??
Any ideas ?
Thanks for any info.
Reza Sharifi Thu, 03/04/2010 - 07:00
  • Cisco Designated VIP,
    2017 LAN
Hi Martin.
It looks as this command has been modified
12.2(4)T
This command was modified to include the ability to use route maps with static translations, and the route-map name keyword and argument combination was added. This command was modified to include static translation with Hot Standby Routing Protocol (HSRP), and the redundancy group-name keyword and argument combination was added. This command was modified to enable the translation of the IP header address only, and the no-payload keyword was added.
Here is command reference guide:
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html#wp1041067
Reza
