03-04-2010 08:18 AM
Hi there,
I am currently evaluating different vendor CNAs and therefore I need to configure different queues with different 802.1p priority bits.
I added a new QoS policy map and my config looks like this now:
Type qos policy-maps
policy-map type qos cna
class type qos class-fcoe
set qos-group 1
class type qos class-default
set qos-group 0
policy-map type qos default-in-policy
set qos-group 1
set qos-group 0
But what I am lloking for is a config like this (up to group/queu 7):
class type qos class-test3
set qos-group 4
class type qos class-test2
set qos-group 3
class type qos class-test1
set qos-group 2
set qos-group 1
set qos-group 0
set qos-group 1
set qos-group 0
The problem is that whenever I try to add new class type qos class-test2 I always get the following error:
ERROR: Class-map class-test2 of type qos not configured
Any ideas??
According to the Nexus 5000 datashet it supports 8 hardware queues so I don't understand why this commadn doesn't work.
Any help is very very welcome!
Thx!
03-04-2010 02:11 PM
Prior to configuring your type qos service-policy, you need to ensure that you created the classification objects first, the error suggests that you have not created the type qos class-maps before creating the policy-map. For example according to your policy-map type qos cna, you should have the following classes already defined in the config:-
class-map type qos class-test3
match
class-map type qos class-test2
match
class-map type qos class-test1
match
etc...
Hope this helps, please rate if you find it helpful
Allan.
03-07-2010 05:47 PM
This is from the Quality of Service Configuration Guide "A total of six system classes are supported. Two of the six system classes are defaults and are always present on the switch. Up to four additional system classes can be created by the administrator."
