Faxserver over ISDN Card
Mar 4th, 2010
we use in our company a faxserver with isdn card.
i try to configure a s0 bus to the faxserver
here a cut from my config:
interface BRI0/3/0 <--- normal phones
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn outgoing display-ie
isdn static-tei 0
trunk-group ALL_BRI 64
interface BRI0/3/1 <-- S0 Faxserver
no ip address
shutdown
isdn protocol-emulate network
isdn layer1-emulate network
isdn skipsend-idverify
line-power
voice-port 0/3/1
compand-type a-law
cptone DE
bearer-cap Speech
dial-peer voice 150 pots
description ** incoming dial peer **
translation-profile incoming PROFILE_ALL_BRI
incoming called-number .%
direct-inward-dial
port 0/3/0
dial-peer voice 153 pots
description ** outgoing dial peer **
translation-profile outgoing PRI-AMT-OUT
preference 3
destination-pattern 0T
progress_ind alert enable 8
port 0/3/0
forward-digits all
no sip-register
dial-peer voice 5029 pots
description S0 Fax
destination-pattern 29
port 0/3/1
no sip-register
i connect the ISDN card on BRI 0/3/1
here a debug isdn q931
000611: Mar  4 16:29:18.583: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, '1751896976'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '2521229'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
000612: Mar  4 16:29:18.599: ISDN BR0/3/1 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling num 001751896976
000613: Mar  4 16:29:18.599: ISDN BR0/3/1 Q931: Sending SETUP  callref = 0x0079 callID = 0x8083 switch = basic-net3 interface = Network
000614: Mar  4 16:29:18.599: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
000615: Mar  4 16:29:18.599: ISDN BR0/3/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
000616: Mar  4 16:29:18.651: %LINK-3-UPDOWN: Interface BRI0/3/1, changed state to up
000617: Mar  4 16:29:22.599: ISDN BR0/3/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
000618: Mar  4 16:29:22.599: ISDN BR0/3/1 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x8083, event 0x95 ces 0
000619: Mar  4 16:29:22.599: ISDN  **ERROR**: Module-CCBRI  Function-_Go  Error-Event received for an unrecognized call.  Data- 95,  0
000620: Mar  4 16:29:26.599: ISDN BR0/3/1 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x8083, event 0xC4 ces 0
000621: Mar  4 16:29:26.599: ISDN  **ERROR**: Module-CCBRI  Function-_Go  Error-Event received for an unrecognized call.  Data- C4,  0
000622: Mar  4 16:29:26.599: ISDN BR0/3/1 Q931: L3_ShutDown: Shutting down ISDN Layer 3
000623: Mar  4 16:29:26.603: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
        Cause i = 0x80A9 - Temporary failure
000624: Mar  4 16:29:26.651: %LINK-3-UPDOWN: Interface BRI0/3/1, changed state to down
000625: Mar  4 16:29:26.675: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
000626: Mar  4 16:29:26.675: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
what is wrong?
Marcos Hernandez Sun, 03/07/2010 - 07:20
  • Blue, 1500 points or more
BRI port 0/3/1 is shutdown. Do a "no shutdown" and try again.
Marcos
