Aaron Harrison Thu, 03/04/2010 - 11:27
THe document you saw really refers to MGCP, where all the dial plan stuff is controlled by CCM.
As you are H.323, you need to enter this command on the voice-port :
connection plar xxxx
Where xxxx is the number you want to dial.
Please rate helpful posts...
aeriksson Thu, 03/04/2010 - 11:58
Sorry I was totally wrong. The VG224 is set up in SCCP-mode. Not H323 as I wrote before.
Gregory Smith Wed, 03/30/2011 - 06:48
No additional configuration needs to be performed on the VG224 assuming the VG224 is working properly otherwise.
If you follow the Cisco instructions and are having issues, you may need to add the partition of the destination DN to the calling search space, not just the newly created autodial partition.
Hope that helps.
