factory reset 7961 phone, now blank screen.......
Answered Question
Mar 4th, 2010
didn't see the erase config option for the phone, to preseve the software load on this phone...did the 1234567879*0# sequence, that didn't help, then 3491672850*#, now phone tries to power up, won't load any software....and this cycles....
i've confirmed that the phone is dhcp'ing an address and attempting to load term61.default.loads, it get's the file, but then doesn't go any further....what do i need to do to complete this factory default process for this phone...
thanks, alex
Correct Answer by Aaron Harrison about 7 years 3 weeks ago
Well - if the phone gets the termxx.default.loads file, but doesn't request anything else, it usually means it doesn't like the way it is signed.
Have a look on your TFTP server for files name SCCP41*.loads - you will probably have several versions.
You can open the current termxx.default.loads file, and see which version is it... then try downloading one of the other SCCP41.loads files and uploading it again as the term41.default.loads file. An older firmware version is more likely to work I would say...
There's a similar problem with Cm7 at the minute - some phones shippped from Cisco recently (or bought a while ago and stored) were signed with an older cert, so won't go direct to the CM7.1 load versions.
Aaron
Overall Rating: 5 (1 ratings)
Aaron Harrison Thu, 03/04/2010 - 11:28
  • Community Spotlight Award,
    Member's Choice, May 2015
You need the phone to get a firmware load it likes - are you by any chance running CM 7.1?
Aaron
Correct Answer
Aaron Harrison Thu, 03/04/2010 - 11:47
Aaron
ALEX CULVER Fri, 03/05/2010 - 06:31
spot on, backed up to 8.3.1s, got my files, rebooted at least 1 time, perhaps 2, then looked back a few minutes later, had my empty/default screen and a webpage off the device, thanks for the advice, was really starting to pull my hair out on this one.
-ac
Related Content
