xconnect not working
Mar 4th, 2010
Hi I am facing issue with configuring xconnect .
I want to configure L3 interface & xconnect in same router. using different physical interface.
Below is the detail :
R1 === > R2 ====> R3
Configured xconnect in R2 & R1.
The Layer 3 interface in configured in R3 & R1
xconnect is configured in R1 with fa0/0 connected to R2
Layer 3 interface in configured with fa1/0
R3 will come to R2 and R2 will encap with l2tpv3 & send it to R1 and in R1 that is bind with fa0/0. But that layer 3 interface in configured in fa1/0 for same to communicate R3.
Please suggest how it will communicate , Here actullay i dont wnat to wast another router next to R1 i.e. R0 , So intead of using R0 i want to configure L3 interface no R1 Itself.
Giuseppe Larosa Thu, 03/04/2010 - 14:16
Hello Chetan,
the xconnect interface has to be at the edge on the two L2 PE routers
No, this is just a terrible mess
see
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
you need to do something like
L2 CE ---- xconnect interface --- R1 --- L3 interface ---- R2 --- xconnect --- R3
you need three interfaces on R1, R1 to R2 interface can also be a serial interface.
to avoid to bypass the L2 service put one interface in VRF and connect  it with a cross-over cable to the one with xconnect.
I guess this is just a lab. There is no great sense in doing  this in real world.
Hope to hlep
Giuseppe
judebryant Thu, 03/11/2010 - 13:11
...so share your solution
I would use xconnect via layer2 with layer3 svi.
How did you solve this issue
Jude Bryant
Pioneer Telephone
Related Content
