Transfer an outside caller to different greeting
Mar 4th, 2010
We use CallManager 4.1(3) and have a Unity 4.0(5) Call Handler as a Auto-Attendant.  We are having trouble with a specific caller calling into out facility and harrassing one of our employees.  I want our phone system to identify this caller (we know their phone #) and send the call to a different greeting other than our auto-attendant.
I've already looked at creating a translation-rule on our h.323 gateway, but I'm not having any success.  Does Unity or CallManager have the ability to route certain callers to different extensions or CallHandlers?
Jaime Valencia Thu, 03/04/2010 - 13:25
  • Cisco Employee,
  • Hall of Fame,
    2011
You can create call routing rules in Unity based on calling number, you can just hang the call or send it to someone or to a call handler.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
zebranutz80 Mon, 03/08/2010 - 12:09
I added an entry for Call Routing(forwarding calls) in Unity. This worked perfectly. Thank you
William Bell Thu, 03/04/2010 - 14:21
  • Purple, 4500 points or more
As java noted Unity can send a caller to a different call handler based on call routing rules.
For the h.323 translation, if you want to just block the call from entering your system (i.e. reject), then the following should work on your h.323 gateway (wouldn't apply to mgcp):
voice translation-rule 99
  rule 1 reject /4085551212/
voice translation-profile blacklist
translate calling 99
dial-peer voice pots 3001
call-block translation-profile incoming blacklist
call-block disconnect-cause incoming call-reject
incoming called-number
direct-inward-dial
port
forward-digits
You would need to apply the "call-block" configs to all dial-peers that could handle an inbound call from the party you wish to block.
HTH.
Bill
