When the phones request the Corporate Directory they append some information to the HTTP request so that CCM returns the correct language (Corporate Directory is basically just a web page on the CCM server).
I would do a packet capture on the handset (verify 'Span to PC Port' and 'PC Voice VLAN Access' are enabled on the phone configuration, then plug a PC running wireshark into the PC port on the phone and start a capture - then access the Corporate Directory).
You should see a request like so:
GET /ccmcip/xmldirectory.jsp?locale=English_United_States&name=SEPUCCX7WS HTTP/1.1\r\n
Except with your phone name and locale. If you see the correct locale, (Spanish_Spain) but CCM returns English, then the problem is more likely to be the CCM software or Locale version.
Can you advise what version of CCM and the Spanish locale you have installed?
Have you installed the locale on all servers in the cluster?
Aaron
Please rate helpful posts...
Aaron
Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
