Cannot ping my own IP address
Mar 4th, 2010
I can't ping my own IP address on switch Cisco2960. I have an identical configuration with exception of IP addresses on it's partner primary switch but I can't ping the IP address of the secondary\backup switch and I could ping the IP address on primary switch.
Please advise.
June
Reza Sharifi Thu, 03/04/2010 - 16:06
  • Cisco Designated VIP,
    2017 LAN
Please advise.
June
Hello June,
Is the backup switch IP in the same subnet as the primary?  Since the 2960s are layer-2 devices you can only have one IP address (svi) at the time and that is for management.
Reza
june_encarnacion Thu, 03/04/2010 - 16:11
Hello Reza,
Thanks for responding to my post.Yes,  the backup switch IP address is in the same subnet as the primary.
June
Reza Sharifi Thu, 03/04/2010 - 16:17
    2017 LAN
Hello June,
So you have an svi configured on each switch and gave it an IP address in the same subnet? Did you also remember to add a port to the vlan?
What is the status of the vlan and the physical interface?
Can you post the config from both switches?
Reza
june_encarnacion Thu, 03/04/2010 - 16:23
Reza,
Please see the configuration below...
(primary)
interface Vlan1
description 1X00507G24-2960.0401
ip address 192.168.83.33 255.255.254.0
no ip redirects
no ip unreachables
no ip route-cache
load-interval 30
(backup)
interface Vlan1
ip address 192.168.83.34 255.255.254.0
no ip redirects
no ip unreachables
no ip route-cache
load-interval 30
June
Reza Sharifi Thu, 03/04/2010 - 16:31
    2017 LAN
What physical port is added to vlan 1 on each switch?
can you post the config?
are they in up and up mode?
what does "sh ip int brie" shows?
Reza
june_encarnacion Thu, 03/04/2010 - 16:43
Reza,
Yes, they are all in up mode. I could actually ping the workstations connected in the backup switch from a different location but not the backup IP address.I'll try to check tomorrow the "sh ip int brie" shows" tomorrow when I get back at site.
June
