Contact Disposition
Mar 4th, 2010
Hi experts.
On Database table ContactCallDetail has a field contactDisposition
What is the calls "do not care" and "Rejected"?
1—Abandoned
2—Handled
3—Do not care
4—Aborted
5-21—Rejected
At tables RtCSQsSummary" and "RtICDStatistics", calls with 3(do not care) and 5-21(rejected) are classified as Abandoned?
thanks
Peterson
Aaron Harrison Fri, 03/05/2010 - 03:49
  • Community Spotlight Award,
    Member's Choice, May 2015
Rejected calls are those that are rejected by the system due to error normally - e.g. you hit the max sessions parameter.
Not sure about 'do not care' - are you seeing calls in your DB logged like this?
Aaron
Please rate helpful posts....
pgcristovam Fri, 03/05/2010 - 04:21
Hi Aaron
Yes, on our BD has some calls with Contact Disposition = 3 (do not care)
Thank you
Peterson
Anthony Holloway Fri, 03/05/2010 - 08:54
  • Purple, 4500 points or more
I just check the UCCX 7.0 DB schema guide, and unfortunately the description for this field is not very helpful.
ktran-anet Fri, 04/09/2010 - 13:15
Peterson,
I found this in the Release Notes for Cisco Customer Response Solutions 4.0(5/5a1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_4_0/release/notes/4.0.5/crs405rn.pdf
Question - What does it mean when the contact disposition is 3?
Answer - When the system cleans up a call, which may have remained in the system because of missing events, the system writes a CCDR with the contact disposition dont_care (value = 3).
lohjintiam Wed, 06/22/2011 - 18:44
Hi all,
Does the CCD table (or any other table) differentiate between calls abandon when its ringing on CAD and calls abandon after RNA timeout?
Thanks!
-JT-
