Low through put on ASA5505
Hi All,
I had changed to ASA5505 for replace Asus router.
But I find the maximum download speed is only 6xx kb/sec with 30M PPPOE Broadband connection
After change back to Asus router, I can get back to 3 mb/sec.
Anyone know the reason?  I should change some setting to let it run to full speed?
Thanks !
p.mcgowan Fri, 03/05/2010 - 03:00
Check speed and duplex settings on both ASA and connected switch ports, check there are no errors in the interfaces of both the ASA and the switch
