Regarding ip routing on 7609
Answered Question
Mar 4th, 2010
Hi Experts,
  I want to know whether ip routing is by default on 7609 or we have to enable it manualy .
Thanks in advance.
Suryakant.
Correct Answer by Jon Marshall about 6 years 10 months ago
suryakant.chavan wrote:
Hi Experts,
Thanks in advance.
Suryakant.
Suryakant
On routers it should be enabled by default. On low end L3 switches you have to enable it ie. 3560/3750. On the 6500 it is enabled by default with native.
So on your 7600 it will be enabled by default. Addtionally see the command reference for the 7600 where it says ip routing is enabled by default -
7600 command reference  - ip routing
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 03/05/2010 - 00:00
Hi Experts,
Thanks in advance.
Suryakant.
Suryakant
Jon
Related Content
