Cat6k Failed to boot up IOS
Mar 4th, 2010
Hi NetPro.
Now hitting another problem for Cat6k. i am doing the patching for Cat6k ... while rebooting the switch directly went to rommon1>. whereby i have checked the boot path and IOS image. everything was ok. the weird thing was from rommon1> i type boot command. it went up for a minute and went down to rommon1> again .....
i am totally no idea how to fix this.. i have tried few times to boot but eventually still failed.
below is the switch info.
Directory of sup-bootdisk:/
    1  -rw-    42878468   Dec 1 2008 17:53:54 +08:00  s72033-ipservicesk9-mz.122-18.SXF12.bin
    2  -rw-      263663  Jul 15 2009 21:56:50 +08:00  crashinfo_20090715-135651
    3  -rw-    43012100  Jan 13 2010 15:48:40 +08:00  s72033-ipservicesk9-mz.122-18.SXF16.bin
512024576 bytes total (425852928 bytes free)
Core#sh hard
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sun 18-Nov-07 06:39 by kellythw
Image text-base: 0x40101040, data-base: 0x42DCBC50
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF12, RELEASE SOFTWARE (fc2)
CS1_CCB_2A uptime is 33 weeks, 1 day, 4 hours, 32 minutes
Time since CS1_CCB_2A switched to active is 33 weeks, 1 day, 4 hours, 33 minutes
System returned to ROM by  power cycle at 17:00:29 CCT Tue Jun 30 2009 (SP by power on)
System restarted at 22:17:13 CCT Wed Jul 15 2009
System image file is "sup-bootdisk:s72033-ipservicesk9-mz.122-18.SXF12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMC11160040
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
78 Virtual Ethernet/IEEE 802.3 interfaces
82 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Core#sh run | in boot
boot system flash sup-bootdisk:s72033-ipservicesk9-mz.122-18.SXF16.bin
boot system flash sup-bootdisk:s72033-ipservicesk9-mz.122-18.SXF12.bin
no ip bootp server
Overall Rating: 2 (2 ratings)
Reza Sharifi Fri, 03/05/2010 - 06:01
  • Cisco Designated VIP,
    2017 LAN
while in rommon. type "set" and see if you are pointing to the right image.  Then do a "dir bootflash:" and see if the image exist in bootflash:
After verifying the image type "boot bootflash:"
Reza
ngengyeong Sat, 03/06/2010 - 08:38
Hi Reza.
thanks for your information, i have checked the directory and the IOS was in the sup-bootdisk: however , when i reboot and the sup engine was not able to boot up the New either the Old , it went to the Rommon directly . then i forced to boot up the Old IOS . it went up for few second and went down to Rommon again. that's why i was surprised why the Old IOS also can't boot up anymore.....
Thanks a lot.
Reza Sharifi Sat, 03/06/2010 - 10:15
    2017 LAN
You can also boot it from disk0 if you have one. Get a CF card and use a good box to copy the IOS into it then put it in  CF slot on the sup and when in rommon. type "boot disk0:and the IOS name"  and see if you can boot it from disk0:
Reza
ngengyeong Mon, 03/08/2010 - 02:47
Hi Reza,
Thanks for sharing , i am just suprised that once the Core switch reboot and it keeping up to Rommon1> ... could it be the hardware problem ?
because, once the switch rebooted and i found there are lot of crashinfo in the directory.
