VPLS Plateform
Answered Question
Mar 5th, 2010
Hi, I'm student and I begin a VPLS project. The aim is to interconnect different sites by VPLS using MPLS backbone. I have already build a MPLS backbone and study many docs about VPLS principes, implementation, and design. However I don't find a lot of thnigs about platerform supported. I think it's not possible on "little" router like 28xx but I'm not sure, I saw on cisco features VPLS build only on 65xx series and 7xxx series.
1. Do you confirm me that ??
2. What IOS version can I use ??
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello Maxime,
yes VPLS requires multilayer switches like C6500, 7600, ME 6524
there is a nice tool that is helpful for this kind of searches named feature navigator
http://www.cisco.com/go/fn
do search by feature, type VPLS
  choice the basic feature that is the expansion of VPLS
in the list of supporting platforms you will see C6500, C7600, ME 6524 and 12000 routers (these with IOS or IOS XR)
if you select C6500 sup720 you can see a list of images that should support VPLS
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 03/05/2010 - 09:37
  • Hall of Fame,
    Founding Member
Hello Maxime,
Hope to help
Giuseppe
Maxime.chevet01_2 Sat, 03/06/2010 - 06:06
Ok, First thanks you for your answer.
I looked Feature Navigator, and I saw many IOS possible to build my plateform. If anyone could help me to choice, I'll be happy. I think virtualize PE (which have VPLS instance) by a software (dynamips/dynagen). I choose "VPLS" feature on CiscoFeatureNavigator but I don't know the difference between 7600, 6000-SUP720, 12000. So I have few questions :
1.  What is the better to vitualize ??
2. Many versions (Adv IP services, SSH, IP simple, adv enterprise), Simple versions are good enough ??
3. Versions are important ?? Between a ED,LD,SHX,SFX...
THanks
Giuseppe Larosa Sat, 03/06/2010 - 06:45
  • Hall of Fame,
    Founding Member
Hello Maxime,
unfortunately emulation of multilayer switches is not possible under GNS3/dynamips see
http://www.gns3.net/phpBB/topic18.html?sid=03884c83158c47ee256713c0967b1f0d
the list of supported devices includes only low end/mid range software based routers.
if you cannot access real devices you will need to build a lab using point-to-point EoMPLS services over emulated C7200.
Hope to help
Giuseppe
Maxime.chevet01_2 Sat, 03/06/2010 - 07:32
I see...
Do you know a another software to virtualize this multilayer switchs ?? Is it possible ??
Giuseppe Larosa Sat, 03/06/2010 - 13:52
  • Hall of Fame,
    Founding Member
Hello Max,
there are no SW simulators for these multi layer switches because they work most in hardware with dedicated and specialized ASICs on their linecards.
Hope to help
Giuseppe
judebryant Thu, 03/11/2010 - 13:09
I would actually use SRE with ES+ cards
with this you have the option for mac in mac.
Jude Bryant
Pioneer Telephone
Maxime.chevet01_2 Thu, 03/11/2010 - 13:33
Well, I try to understand your answer but I don't. Can you explain with others words. You have a solution to my problem?? What is mac in mac??
Thanks to help me.
ps: I think build a LAB with EoMPLS like Guilsar told me. However if I succeded to have a 7300 I will be happy and VPLS will come back.
judebryant Thu, 03/11/2010 - 14:33
ok so as per this diagram
(lan)<=>--MPLS Cloud---<=>(lan)
the ingress and egress points to and from the lan should be interfaces configured for vpls
vpls is a multipoint ethernet over mpls solution.  however when you type in the xconnect command
mac learning is turned on.  All of the MAC address from the two lans are learned inside of the mpls cloud.
this is the behaviour of multipoint to multipoint or etree/elan.
so in a point to point ethernet over mpls which is a pseudowire mac address are not learned because its point to point.
so with the vpls environment when using ios sre with the es+ cards.  with this compination.  you can hide the mac addresses
of the lan by representation of a mac address.  Just think of it as qinq.  you put an outer vlan tag on already tagged traffic.
so in this case you are creating a virtual mac address to represent one lan, and another virutal mac address to represent the other.
so all you have in the middle are two mac address.
hope this helps
Jude Bryant
Pioneer Telephone
please excuse any typos...im tired
Giuseppe Larosa Fri, 03/12/2010 - 05:40
  • Hall of Fame,
    Founding Member
Hello Jude,
Maxime is a student and he is working on his thesis, my understanding is that he hasn't access to real devices for this reason I had suggested him to emulate an EoMPLS using emulated C7200 devices.
However, what you have described is interesting and could be part of a theorical part of his thesis where he will describe industry solutions for scalability.
Hope to help
Giuseppe
judebryant Fri, 03/12/2010 - 07:03
hello there,
the configuration I explained is a part the the AoMPLS or any over MPLS.
the standard is Mac-in-Mac or 802.1 ah.  Search this and you will find some additional info
here is a link for additional info from Cisco
http://www.cisco.or.at/web/HR/assets/images/Novosti_u_Carrier_Ethernet_produktima_za_pruzatelje_telekomunikacijskih_usluga_-_Josef_Ungerman.pdf
good stuf.
Jude Bryant
Pioneer Telephone
