SNMP Credentials Change - Must specify sysObjectID/MDF type
Mar 5th, 2010
We are running LMS 3.1 on Windows 2003R2.  I've carried out a change which changes the 'default SNMP Credentials' which we use to carry out our device imports from Cisco ACS.  Also I have changed the SNMP credentials for all the devices from the DCR (approx 1600).  All seems to have gone through ok except for 3 devices which have returned with:
  • Must specify sysObjectID/MDF type
Any ideas on how can I correct this problem ?
Many Thanks
Joe Clarke Fri, 03/05/2010 - 09:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
To be clear, you're importing a CSV file into DCR, and seeing this error for three of the devices?  If so, exactly what fields in the CSV file are populated for these devices?
dmistry21 Fri, 03/05/2010 - 09:19
What i'm doing is updating the SNMP credentials within the DCR by going to:
  • Common Services -> Device and Credentials -> Device Management -> "selecting All Devices" -> Edit Credentials - and then changing just the SNMP RO Community String.
It takes me through all the steps but gives me the error once clicking Finish.
Joe Clarke Fri, 03/05/2010 - 09:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What are the three devices that are failing?  Can you provide a DCR export of those devices?
dmistry21 Fri, 03/05/2010 - 09:58
Bit of a mixed bag here looking into them:
I can snmpwalk two of the devices and they are a:
  1. "Cisco IOS Software, C2960 Software (C2960-LANBASE K9-M), Version 12.2(44)SE1, RELEASE SOFTWARE (fc1)
  2. "Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(19b), RELEASE SOFTWARE (fc1)
The other device I cannot snmpwalk to but if it is model/ios dependant, hopefully the above may help if they can be resolved.
Joe Clarke Fri, 03/05/2010 - 09:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What about the DCR export?  I would need to see the attributes currently in DCR for these devices.
dmistry21 Sun, 03/07/2010 - 06:53
Unfortunately i'm not permitted to provide the DCR export.
I'll try removing the devices from the DCR and try a re-import and see whether I get the same error.
Also I may have to try amending the individual attributes of the devices in the DCR.
