2501 Router that will not boot
Brent Catoe
I have a 2501 router that I use as an access router. When i boot it up all I get is this,
System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
Copyright (c) 1986-1995 by cisco Systems
nothing else after those lines, i cannot Ctrl+Break to get into rommon. If i remove a memory module and try to boot it I get this.
Bad memory - wrote zero, read 0xFFFFFFFF at location 0x00000010
any ideas?
Kevin Dorrell
Level 10
Level 10
I know it sounds silly, but how much time did you allow it?  Some old 2500s can be  S--L--O--W  to boot.  I don't know whether it's my imagination, but it seems that if you put "unknown origin" memory modules in it, it is worse.
Kevin Dorrell
Luxembourg
pompeychimes
Level 4
Level 4
Is the fan running? Try reseating all memory. Try using different memory if you have it.
James
