%LTL-SP-2-LTL_PARITY_CHECK: LTL parity check request for xxxxxx
rocco.scholz
on a catalyst 6513 we experience the following error message for several times,
%LTL-SP-2-LTL_PARITY_CHECK: LTL parity check request for 0xD4B6
The switch is working properly and we don't experience any problems. I've tried to find a hint at Bug Tool Kit and also Error Message Decode but without success. Could anyone tell what causes these errors and what to do.
used IOS --> s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI3
Thanks in advance.
regards,
Rocco
Ganesh Hariharan
Thanks in advance.
regards,
Rocco
Hi Rocco,
Check out the below link hope that help !!
http://www.cisco.com/en/US/docs/ios/12_2sx/system/messages/sm2sx05.html
Ganesh.H
jgeralsky
Starting in IOS release SXI (enhancement bug id  CSCsl42288), an LTL/FPOE consistency
checker has been enabled. So periodically the hardware LTL/FPOE states are compared
against the same software entries. If an inconsistency is identified, it is corrected and
a message logged. This is the reason you observed the following logged message. These
messages indicate that an error was found, and it was corrected.
esomarriba
Level 5
Level 5
reduce you syslog history buffered, you should get rid of this msg. I had the same issue on my network.- OR get some more memory if supported on your platform.-
