Caller id's first character is stripped
Answered Question
Mar 5th, 2010
We
have one site from which  all the incomming calls comming with the first character of the caller id  stripped .On ip phone  we get the id as
example  :   ohn   instead of  john
Need help please if any one
Thank you
Correct Answer by Jaime Valencia about 6 years 11 months ago
first letter missing in incoming caller name display
1. Change the switch-type in the IOS gateway to Primary-dms100
2. Change the switch-type in gateway's configuration in the CallManager configuration to primary-dms100
3. Ensure that the option 'Send Extra Leading Character in Display IE' is checked in the gateway's configuration in CallManager.
4. Test inbound calls for correct caller name
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 03/05/2010 - 06:29
java
is_mail123 Thu, 03/11/2010 - 10:59
I am using ccm 7.1 there i dont have this  'Send Extra Leading Character in Display IE'  in phone configuration can u please help us we are still facing problem
Related Content
