03-05-2010 06:59 AM - edited 03-15-2019 09:39 PM
Hi All,
I have installed Call manager 6.0.1 and IP Communicator 7. Also I have configured Extension Mobility. While Login and Logout I am geeting XML ERROR [4] : PARSE ERROR.
The extension Mobility feature is working fine.
Could you please help me to address the issue.
Nirmal
Solved! Go to Solution.
03-05-2010 07:07 AM
First of upgrade your Cluster to a later version of Callmanager 6.1(4) something.There are alot of issues in the early version of the code which will cause you issues.To that first and i bet the issue will go away.
Cheers
Mark
03-05-2010 07:07 AM
Cheers
Mark
