03-05-2010 07:15 AM - edited 03-06-2019 10:00 AM
I've got an 8510 that's showing this error in the log:
Mar 5 09:33:28.736: %AAL5-3-INTERNAL_ERROR: aal5send: mmc_queuecell failed No room on port 0 vpi 0 vci 5 for cells 1
This happens about twice a minute, about 5 seconds apart. I haven't really run across much online about this message. No performance problems yet, but I want to get this figured out before there are. Anybody know what's causing this?
Thanks!
03-05-2010 07:24 AM
No room on port 0 vpi 0 vci 5 for cells 1This happens about twice a minute, about 5 seconds apart. I haven't really run across much online about this message. No performance problems yet, but I want to get this figured out before there are. Anybody know what's causing this?
Thanks!
Check out the below link with clear explanation about the error.
Remember to rate the helpful post
Ganesh.H
03-05-2010 07:44 AM
Yes, I have seen that... it's one of the few posts that show up in a search for this error. Unfortunately, the commands it gives to try return nothing. Show epc queuing shows only the headers and show epc status comes back blank. Show mmc ports is now recognized.
