RV082 VPN logs looks like an attack
Mar 5th, 2010
I´m seeing this lines in the VPN Log of our RV082.
My questions are:
  • is if these are normal logs or if it could be an attack?
  • is there any exploit for RV082 that I should be aware of?
  • can I disable VPN completelly?
I'm not expeting any client connecting to the RV082.
My router: RV082 with firmware 2.0.0.19-tm
Here are the logs, the repeats every day, every few hours. Please note the same timestamp in some entries
Mar  5 08:25:21 2010    VPN Log   Received Vendor ID payload Type = [Dead Peer Detection]
Mar  5 08:25:21 2010    VPN  Log   [Tunnel Negotiation Info] <<< Responder  Received Main Mode 1st packet
Mar  5 08:25:21 2010    VPN  Log   (NATT)Initial Main Mode message received on MY_IP:500 but no connection has been authorized. Please check  your tunnel endpoint (gateway) setting
Mar  5 08:25:21 2010    VPN  Log   Dynamic VPN client in Main Mode is only supported for  Microsoft VPN client, please use Aggressive mode instead.
Mar  5 08:25:41 2010    VPN  Log   Received Vendor ID payload Type = [Dead Peer Detection]
Mar  5 08:25:41 2010    VPN  Log   [Tunnel Negotiation Info] <<< Responder  Received Main Mode 1st packet
Mar  5 08:25:41 2010    VPN  Log   (NATT)Initial Main Mode message received on MY_IP :500 but no connection has been authorized. Please check  your tunnel endpoint (gateway) setting
Mar  5 08:25:41 2010    VPN  Log   Dynamic VPN client in Main Mode is only supported for  Microsoft VPN client, please use Aggressive mode instead.
Many thanks
Oliver
http://tinymaillto.com/oliversl <-- my email after a captcha
oliversl1 Sat, 03/06/2010 - 06:40
The other side RV082 VPN Tunnel was not disabled, that was the cause :(
