Troubleshooting Inbound Busy Calls
I am having a problem with a site that is stating they get complaints of a busy signal when dialing a DID. I have looked at the call manager logs and CCDR and I don't seem to see anything. Is there a way for me to set up logging on an H323 gateway so I can capture all inbound call attempts to see if I am having a problem before the call gets to the CM? Any help is appreciated.
Aaron Harrison Fri, 03/05/2010 - 08:28
Assuming you have ISDN PRI or BRI, you can run the command 'debug isdn q931' on the gateway to see all ISDN setups/disconnects etc.
