CUEAC - Install error 0x8007000B with 3.1.1.x
Mar 5th, 2010
Good Morning,
I am trying to install EAC on a Win 2008 server box with SQL 2008. The release notes for 3.1.1.8 say this is supported. The error indicates "an attempt was made to load a program with an incorrect format" which often is related to 32-bit dlls. I was never presented the "Database Wizard" screen (Step 11 of the install).
I have attached two screenshots showing the install error and the environment.
Is this a known issue I can get around or should I just go back to the win 2003 environment where it seems to work for most posters in this forum? What OS, SQL and AC version combinations are known to actually work? We need 25 consoles so SQL express is not an option.
Thanks in advance,
Greg
Related Content
