Several SSIDs can not be broadcast AP 1242
Answered Question
Mar 5th, 2010
I have tried to configured an AP 1242 Version 12.3(8)JEA2 with 3 SSIDs  , every SSID assigned to a VLAN, but I haven't been able to broadcast the 3 SSIDs at the same time. If I broadcast one the others are not broadcast; several times the following  message  appears "SSID vlanX replace SSID vlanx
as the broadcast SSID.
How can I solve this issue???
regards
Correct Answer by Scott Fella about 7 years 1 month ago
Try to use this command under the dot11 ssid:
mbssid guest-mode
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Fri, 03/05/2010 - 12:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
mbssid guest-mode
filiberto.aguirre Fri, 03/05/2010 - 15:03
Hi Scott,
Thanks a lot for your suggestion,
You are right !!
in addition to the mbssid guest-mode commmand under dot11 ssid, I have to set mbssid under interface dot11.
Scott Fella Fri, 03/05/2010 - 15:40
  • Hall of Fame,
    2017 Wireless
Glad you got it working.
