Webview-Delete shared reports
Mar 5th, 2010
Is there any way to delete saved reports? We have had several users that have left the company and there is a growing amount of saved reports in Webview that are no longer needed. I am unable to delete the reports because I did not create them. Is there a way to create a user account with higher credentials in order to delete those reports?
SYSTEM VERSIONS
ICM 7.2(5)
CTIOS 7.2.(5)
CAD 7.2.1 (premium)
CCM  6.1.2.1000-13
IVR 5.0(2)SR02_Build045
Webview 5.0
Don't you have access to the Administrator login to WebView?
I would imagine you can delete these using SQL Query Analyzer against the "wv" database on your AW/HDS, given the correct credentials.
One other point - why do you list your WebView version at 5.0? Upgrades to the ICM system normally get applied to the WebView server also.
Geoff
david.macias Sun, 03/07/2010 - 05:17
  • Blue, 1500 points or more
A sure way to do this is to reset their WebView login and login as them and delete them.  Might take a while, but could be added as part of your hire/dismiss process.
david
