What does this error mean:"%OIR-SP-4-WARN: PRIMARY(1) REPORTED AS NOT OCCUPIED IN SLOT!! disable_reason: 15(off (Re set)), get_peer_previous_slot: 0, is_occupied"?
Mar 5th, 2010
This is a 6509 with Sup-2/MSFC2.  Can't find any reference to this error on the cisco web site.
Giuseppe Larosa Fri, 03/05/2010 - 11:28
  • Hall of Fame,
    Founding Member
Hello Lojo,
this is a message from redundancy feature
do you have two sup2/MSFC2 in this C6500?
OIR = online insertion and removal
SP = switch processor
WARN = severity level 4
primary = referred to primary active supervisor
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/system/messages/edesc.html#wp1041280
FACILITY-SOURCE-SEVERITY-MNEMONIC: Message-text
the master supervisor was considered off line for a short time
if you issue a sh redundancy do you see two supervisors?
Hope to help
Giuseppe
Eicke Friedrich Sun, 07/29/2012 - 23:37
We had the same issue here in a 6506. But the message came together with
%C6KENV-SP-4-FANTRAYFAILED: fan tray 1 failed
%C6KENV-SP-4-FANTRAYOK: fan tray 1 OK
after replacing the faulty fan tray both error messages disappeared. So the message
"%OIR-SP-4-WARN: PRIMARY(1) REPORTED AS NOT OCCUPIED IN SLOT!! disable_reason: 15(off (Reset)), get_peer_previous_slot: 0, is_occupied fn ptr:0x40499798" was a bit misleading.
/Eicke
