Warning message
LMS3.1/RME: inventory report
Mar 5th, 2010
I would like to get an information about gigaStack port on switch inventory.
I have generated an Detail device Report but I didn't get this information.
I can find this information by show interface status | include GigaStack on switch :
Gi0/1                        connected    trunk      a-full a-1000 1000BaseCX Gigastack
Gi0/2                        connected    trunk      a-full a-1000 1000BaseCX Gigastack
So, I try with RME -> Tools -> Netshow. see file attached.
I get the information but I prefered to get it in with a report because I need to get thoses informations for 150 devices.
Is there a way to get it on a report ?
When I look at RME->Admin-> Inventory-> Change Filter,
I think that there are more port information compare to report generator.
Status
Parent Relative Position
Port Interface Index
Operational Status
Manufacturer Name
Field Replaceable Unit
Alias Name
Slot Configuration
Port Model Name
Port Vendor Type
Power Remaining
Port Serial Number
Power Consumption(%)
Description
Power Consumption
Component Type
Power Available
Port Index
Power Allocated
Maximum Power
POE Admin Status
Physical Entity Name
Custom report, port attribute, I can take only thoses attributes:
Maximum Power
Power Allocated
Power Available
Power Consumption
Power Remaining
POE Admin Status
Why there are more infiormation for change audit than inventory report ?
Thanks, Elisabeth
Inventory Change Filter : Port
Joe Clarke Fri, 03/05/2010 - 11:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I have a bug open to make sure all of the inventory attributes seen in the Detailed Device Report are also available for custom reports (CSCsj78780).  Quite a few were added in RME 4.3, but the list is still not complete.
As for Netshow, there is no way to change the output format type (i.e. you cannot make it more like the inventory reports).  However, you could perhaps write a script to parse the CLI output from Netshow, and deliver a report in the desired format.
ebezombes Fri, 03/05/2010 - 13:16
Do you think that there is an attribute or an snmp variable for GigaStack information like I can get with show status ?
Port      Name               Status       Vlan       Duplex  Speed Type
Joe Clarke Sat, 03/06/2010 - 06:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't think so, but I do not have a 3750 with a Gigastack GBIC with which to test.  If this data is available in RME, it would be visible in the Detailed Device Report.  However, I think the type attribute will only indicate it is an ethernet port.
