Regular Expression Question for blocking and redirecting
Answered Question
Mar 5th, 2010
I am currently using regular expression to block certain websites.  I have two questions about this.  My regular expressions are working fine, what I would like to know is if I can have more than value defined in each expression.
Example
currently I have blockedsite1 ---> facebook\.com, blockedsite2 -->myspace\.com
Is there a way to combine them into one such as (I know the syntax is not correct) blockedsite1 --> facebook\.com;myspace\.com
Second question.  Is there a way in the regex to define a redirect.
Example:  A user hits facebook.com.  Can the regex or another rule based off the regex redirect the user to our corporate website.
Thanks in Advance
l8nite
Correct Answer by Kureli Sankar about 6 years 10 months ago
I am not sure if either of them is possible.
Pls. refer this link: http://supportforums.cisco.com/docs/DOC-1268
regex command reference: http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/qr.html#wp1788742
Alternation
Matches either expression it separates. For example, dog|cat matches dog or cat.
See if you can use the above metacharacter and see if you can do what you are looking to do.
-KS
Overall Rating: 5 (1 ratings)
Correct Answer
Kureli Sankar Fri, 03/05/2010 - 15:50
Alternation
-KS
