InterCluster call flow
Mar 5th, 2010
Hi all,
If I have two CCM clusters (CCM cluster 1 and CCM cluster 2) and i need to route calls from CCM cluster 2 to reach the MGCP gateway controlled by a CCM from cluster 1 to make outbound calls (PSTN), what should be configured to make that possible?
Overall Rating: 4 (1 ratings)
Jaime Valencia Fri, 03/05/2010 - 12:36
An ICT between the 2 clusters, the inbound CSS from cluster 1 being able to reach the route pattern for the MGCP GW.
Obviusly you need to create the patterns and necessary transformations as needed to make it a PSTN routable call.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
