03-05-2010 12:56 PM
A PIX501 should be able to connect to an ASA5520 on a S2S VPN if they are on the same version of code, etc. correct?
Solved! Go to Solution.
03-05-2010 01:21 PM
They do not need to be on the same version of code. The latest code for a PIX501 is 6.3(5) and an ASA can't run code that low. There is no problem swith each having different spec's.
Hope it helps.
03-05-2010 08:54 PM
They both follow the RFCs, regardless of code version. You're good to go.
03-05-2010 01:21 PM
Hope it helps.
03-05-2010 08:54 PM
