4507 IOS mismatch
Mar 5th, 2010
Is there anyway for me to push the newer ios (  12.2(53)SG1 ) to the Primary sup without having to reboot?
sw-517-core-can-4507R-01#sh module
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE1220IA4W
2    48  10/100/1000BaseT (RJ45)V, Cisco/IEEE   WS-X4548-GB-RJ45V  JAE1228ORR2
3     6  Sup 6-E 10GE (X2), 1000BaseX (SFP)     WS-X45-SUP6-E      JAE1224LNT4
4     6  Sup 6-E 10GE (X2), 1000BaseX (SFP)     WS-X45-SUP6-E      JAE1224L3JY
5    48  10/100/1000BaseT (RJ45)V, Cisco/IEEE   WS-X4548-GB-RJ45V  JAE1228OTNL
M MAC addresses                    Hw  Fw           Sw               Status
1 001f.caee.9f30 to 001f.caee.9f5f 2.5                               Ok
2 0022.55e7.91a0 to 0022.55e7.91cf 4.1                               Ok
3 001d.700f.3080 to 001d.700f.3085 1.1 12.2(44r)SG  12.2(50)SG       Ok
4 001d.700f.3086 to 001d.700f.308b 1.1 12.2(44r)SG  12.2(53)SG1      Ok
5 0022.553e.a4d0 to 0022.553e.a4ff 4.1                               Ok
Mod  Redundancy role     Operating mode      Redundancy status
3   Standby Supervisor  SSO                 Standby hot
4   Active Supervisor   SSO                 Active
Reza Sharifi Fri, 03/05/2010 - 19:36
  • Cisco Designated VIP,
    2017 LAN
Hi Brent,
Every time you load a new you have to reboot the box in order for the new software to load.  Since you have redundant Sups in your box and they are running in SSO more, you can use ISSU to upgrade without any downtime. They way it works is that you load the new IOS into the stand-by sup and reboot.  after that you force the stand-by to be the primary and now you load the IOS in the other SUP and reboot  You have to follow the instruction to do it correctly.  I would caution you to do this during an outage window.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/issu.html
Good Luck
Reza
