03-06-2010 06:59 AM - edited 03-06-2019 10:01 AM
I have an ISR2811 with a primary BGP learned route via ethernet and a backup BRI connection with a floating static route (admin distance of 200). The site learns routes via BGP over the primary connection when the primary connection is in place. During a primary ckt failure, the BRI comes active and connectivity to the remote LAN works via the backup connection/floating static route. However, when the primary connection comes back, the router doesn't drop the floating static route/BRI and contintues to route over it.
If I remove the floating static route and re-add it; the router drops the BRI and routes over the primary link via BGP. I've tried an admin distance of 250 on the FSR. BGP come in with an admin distance of 20. Please see below.....Am I missing something simple? This is a new BGP config with a newly updated ISR (from 12.3 IP Base to 12.4 SP Services).
Thanks!
ROUTER#sho ip route 192.168.12.0
Routing entry for 192.168.12.0/24
Known via "static", distance 254, metric 0
Redistributing via bgp 65476
Advertised by bgp 65476
Routing Descriptor Blocks:
* 192.168.212.2
Route metric is 0, traffic share count is 1
ROUTER#config t
Enter configuration commands, one per line. End with CNTL/Z.
ROUTER(config)#no ip route 192.168.12.0 255.255.255.0 192.168.212.2 254
ROUTER(config)#do sho ip route 192.168.12.0
Known via "bgp 65476", distance 20, metric 0
Tag 4323, type external
Last update from 198.18.23.145 00:00:05 ago
* 198.18.23.145, from 198.18.23.145, 00:00:05 ago
AS Hops 2
Route tag 4323
ROUTERconfig)#ip route 192.168.12.0 255.255.255.0 192.168.212.2 254
Last update from 198.18.23.145 00:00:15 ago
* 198.18.23.145, from 198.18.23.145, 00:00:15 ago
AS Hops 2
Route tag 4323
Last update from 198.18.23.145 00:00:17 ago
* 198.18.23.145, from 198.18.23.145, 00:00:17 ago
AS Hops 2
Route tag 4323
ROUTER(config)#end
Solved! Go to Solution.
03-06-2010 10:19 AM
Hello Mmertens,
first show in first post is meaningful:
* 192.168.212.2
when primary route fails the secondary route is installed but it is also redistributed and advertised into BGP.
Being a locally generate BGP route it has a BGP weight of 32,768
when primary route comes back is not treated anymore as the best BGP path because BGP weight is looked first and makes the locally generated route to be preferred.
To have a correct behaviour in restore you can provide an higher weight to eBGP neighbors
router bgp 65476
address-family ipv4
neigh 198.18.23.145 weight 40000
this should solve your issue
Hope to help
Giuseppe
03-06-2010 07:18 AM
Can you paste the output of the below command
#sh run | b r b
I hope we need to refresh the BGP.
# clear ip bgp soft out.
Karuppu
03-06-2010 07:26 AM
Karuppu,
Here's my BGP config: I can try try the the soft reset and see what happens. Thanks!
router bgp 65476
bgp log-neighbor-changes
neighbor 198.18.23.145 remote-as 4323
address-family ipv4
neighbor 198.18.23.145 activate
no auto-summary
no synchronization
network 172.30.1.0 mask 255.255.255.128
network 198.18.23.144 mask 255.255.255.252
exit-address-family
03-06-2010 08:49 AM
Whenever the primary link comes up, obviously the BGP neighborship should be up.at that time can you check weather are you able to recieve the routes from your neighbor by the use of below command
#show ip bgp neighbors 198.18.23.145 received-routes
Can you check weather the necessary routes are present in your BGP table.
Can you paste the output the below command when static route is installed in your routing table
#sh ip bgp 198.168.12.0
Karuppu
03-06-2010 10:19 AM
Hello Mmertens,
* 192.168.212.2
router bgp 65476
address-family ipv4
Hope to help
Giuseppe
03-09-2010 10:29 AM
Giuseppe,
That was it! Thanks tons!!!
