Configuring ASA 5505 as VPN with SDM
Mar 6th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:Arial; mso-bidi-theme-font:minor-bidi;}
I am setting up a VPN for a client, they have a leased line from ISP using Cisco router 800 series with ADSL port, it is setup with 1 VLAN with real IP address 62.68.59.161, I have setup my ASA5505 as a VPN with IP address 62.68.59.164 on the outside port and the inside network is 192.168.1.0.
All settings look ok. This is the problem I am having, when I use a Cisco VPN client it is unable to find the security device at 62.68.59.164. I am unable to ping this port, even though I have enabled IP on the port. I am able to ping 62.68.59.161 which is the router port.
Anything I am missing? Please help.
