CUCM 7.1 3b on IBM X 3650 M2
Mar 6th, 2010
HI all,
Iam trying to install CUCM 7.1 3b on a customer provided IBM x 3650-M2 Xeon 4C E5540 80W 2.53GHz/1066MHz FSB/8MB L3, 2x4GB with 4 *146 GB hardisk.when i insert the CUCM 7.1 system installation DVD it throws an error as "expecting 4 hardisks but 0 found" and "Expecting 2 CPU but one found".
Could any one tell me as how to install CUCM on this Server?
I have verified the CUCM support for this hardware and it shows positive.
David Hailey Sun, 03/07/2010 - 19:42
Have you build the RAID array and such with the manufacturer provided DVD/CD's for drivers, RAID, etc?  If not, that's the first place to start.  When you buy OEM from Cisco, the servers are pre-built to platform install.  When you buy from the manufacturer they are typically empty images and need to be imaged to a point where hardware validation will work.
Please rate helpful posts.
