Ganesh Hariharan Sun, 03/07/2010 - 21:11
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
What would be the best way
to provide layer 2 connectivity between 2 data centers? Sample router configs?
Thanks!!
Gary
Hi Gary,
Data Center to Data Center can be conencted in diffterent ways like point to point link,over the MPLS or some other means and cofniguration all depend on the connectivity what exactly is with your current network setup.
Check out the below link on Data Center interconnect consideration.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11_493718.html
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
shailesh.h Tue, 04/13/2010 - 08:55
  • Bronze, 100 points or more
Hi Gary,
I was looking at your requirement and not clear what exactly you want to achieve for L-2 across two data centre...
1..There are different options available with L-2 connectivity across two data centre -- most commonly extend LAN and configure as one data centre to external world..
2.. you can reduce the number of network devices across data centre by putting primary devices at one site and secondary / standby at other site..
If you state few of your requirement would be great help to suggest further..
Shailesh
Trending Topics: Other DC Subjects
