Pay Phones with Cisco CallManager
Mar 7th, 2010
Hi All,
Can any one tell me if any kind of pay phones(whether Analog or IP) works with Cisco callmanager,
If yes which vendor best goes with cisco.
Bejoy Thomas
kellymaloy Thu, 03/11/2010 - 12:22
Back in the day, you used to order a special phone company circuit for pay phones, but modern pay phones will connect to a standard analog line. That means you can plug a payphone into an FXS port on your Cisco System (using an ATA, or a VG gateway). However, it's recommended to order a direct line from the telco for your payphone, instead of connecting it behind your Cisco switch (for fraud prevention purposes).
Cisco doesn't manufacture payphones, so you'll need to go with a third party manufacturer. Just google "payphones," and you should find plenty in the range of a few hundred dollars or less. Any quality third party manufacturer should work fine.
Good luck.
Kelly
[email protected]
