Do ACLs on WLCs limit throughput
Mar 7th, 2010
My boss wants me to create a WLAN for guests, so I created and VLAN and SSID for them and used a webauth bundle with an accept button.  Next I was told the WLAN needs to be limited to DHCP, DNS, HTTP and HTTPS.  I created an ACL on the controller and tested it.
My throughput is cut by 66% on 802.11a/b/g access points, but seems to have no effect on the 802.11n access points.  My normal download is about 22 mb/s on 802.11g, but with ACL applied, it dwindles down to 7mb/s.
Should I be placing the ACL on the 6509 that is the host chassis for the WLC?
Are there any other suggestions?  What is everyone else doing?
Thanks in advance,
Tim
Scott Fella Sun, 03/07/2010 - 08:01
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I have only used ACL's on the WLC in a lab environment and removed it when I put it into production.  I would never use it in a production environment.  Either place your ACL's on your L3 devices or use a FW if guest traffic is either directed out to the DMZ or if you are using guest anchoring.  I never did see any throughput drop, but then again never used ACL's in a production network.
http://www.cisco.com/en/US/docs/wireless/technology/guest_access/technical/reference/4.1/GAccess_41.html
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00809ba482.shtml
Here is a thread than has some info also:
https://supportforums.cisco.com/message/3005351;jsessionid=7210AE0A26503F13C80A4ACE966D1DCF.node0
Trending Topics - Security & Network
