seegomaa Sun, 03/07/2010 - 21:51
Thanks Reza for you answer. The command is not there, i beleive it has different syntax on NX-OS.
The document you sent is explaining how to do it through the setup utility
Ganesh Hariharan Sun, 03/07/2010 - 22:05
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the below link on routing configuration on nexus hope to help !!
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/unicast/configuration/guide/l3_nx-os.pdf
Ganesh.H
