traceout command
Answered Question
Mar 7th, 2010
hi..simple question,
how to apply traceout command ....on the pc or router??
what is the command
thx
Correct Answer by Ganesh Hariharan about 7 years 1 month ago
what is the command
thx
The Linux traceroute command is similar to       the Cisco router implementation. However, it uses a fixed source port. The       -n option in the       traceroute command is used to avoid a request to a       name server.
where as in PC like windows tracert command is used followed by ip address.
Check out the below link hope that helps
http://www.cisco.com/en/US/tech/tk364/technologies_tech_note09186a00801ae32a.shtml#lin
Remember to rate the helpful post
Ganesh.H
Correct Answer by Reza Sharifi about 7 years 1 month ago
On router
T-1#traceroute 10.0.3.3
On Pc
tracert 10.0.3.3
Reza
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Sun, 03/07/2010 - 10:45
  • Cisco Designated VIP,
    2017 LAN
On router
On Pc
tracert 10.0.3.3
Reza
Correct Answer
Ganesh Hariharan Sun, 03/07/2010 - 21:52
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
what is the command
thx
Ganesh.H
Ganesh Hariharan Mon, 03/08/2010 - 22:29
That great the comments are helpful it will be great if you mark this thread as answered so that others get benifitted.
Ganesh.H
