workstations loose connectivity to gateway periodically
Mar 7th, 2010
I'm working on a small LAN with WinXP workstations and a 2621 router as a gateway. Randomly workstations loose connectivity to the gateway. Cannot ping the router interface at fa0/0. If I repair the connection on the workstation it fixes the issue. Any ideas?
Bill
KARUPPUCHAMY MA... Sun, 03/07/2010 - 17:30
  • Silver, 250 points or more
Just clarify the below questions
1.Is your DHCP server is configured on the windows server or the router is acting as a DHCP server,
2.paste the output of the command #sh run int f0/0
Karuppu
bbuhlman Sun, 03/07/2010 - 17:38
The windows server is the DHCP server. Router is not acting at DHCP.
interface FastEthernet0/0
description Local LAN
ip address 10.0.1.1 255.255.255.0
ip nat inside
no ip mroute-cache
speed 100
full-duplex
KARUPPUCHAMY MA... Sun, 03/07/2010 - 18:09
First you need to configure ip helper-address command in f0/0 interface to forward all the DHCP request from the desktops to DHCP server.
(config)# int f0/0
(config-if)#ip helper-address
Parallelly check the leased time in your DHCP server for this DHCP pool
Karuppu
bbuhlman Sun, 03/07/2010 - 18:29
The dhcp server is on the same LAN as the workstations, doesn't everyone on the LAN look at the UDP broadcasts? I added the helper address anyway and the lease time is 8 days.
johnlloyd_13 Sun, 03/07/2010 - 21:07
  • Blue, 1500 points or more
could we have a brief description of your LAN. i've some few questions regarding your issue:
1. are you using wireless LAN for PC/laptop connectivity?
2. is there a LAN switch between PCs and router? PC --> SWITCH --> ROUTER; if yes, what is the speed/duplex on LAN switch port?
3. what does your router syslogs shows (show log)? check the same if using LAN switch
4. kindly provide your PC tracert to LAN gateway
