Redundacy Not happening after interface goes down.
Answered Question
Mar 7th, 2010
Dear All,
I have the set up which I have attached. To brief, I have 2 CSS 11501 in two different locations connected each other via fibre and running redundnacy protocol on the link as heartbeat.
The problem I am facing is if the interface through which the services are running fails the redundancy is not happening the master remains the master and the standby is standby and we have a services unavailable.
the configuration is given below
CSS_ACTIVE# sh run
!Generated on 03/07/2010 22:26:21
!Active version: sg0810106
configure
!*************************** GLOBAL ***************************
  username admin des-password lcof1eugqece2afd superuser
  bridge spanning-tree disabled
  arp timeout 1400
  no restrict web-mgmt
  ip redundancy master
  app
  app session 10.90.1.2
  ip route 10.50.3.0 255.255.255.0 10.50.9.1 1
!************************* INTERFACE *************************
interface e1
  trunk
  vlan 11
    default-vlan
  vlan 20
  vlan 21
interface e9
  description "REDUNDANCY - CSS-STANDBY PORT 9"
  bridge vlan 23
!************************** CIRCUIT **************************
circuit VLAN11
  description "MANAGEMENT IP ADDRESS"
  ip address 10.7.10.20 255.255.255.0
circuit VLAN20
  description "CSS_SERVER_VLAN"
  redundancy
  ip address 10.50.7.4 255.255.255.0
circuit VLAN21
  description "CSS_CLIENT_VLAN"
  redundancy
  ip address 10.50.9.7 255.255.255.0
circuit VLAN23
  description "REDUNDANT LINK TO CSS-STANDBY"
  ip address 10.90.1.1 255.255.255.0
    redundancy-protocol
!************************** SERVICE **************************
service Web1
  ip address 10.50.7.5
  active
service Web2
  ip address 10.50.7.6
  active
!*************************** OWNER ***************************
owner KIM
  content web
    add service Web1
    add service Web2
    vip address 10.50.9.2
    advanced-balance sticky-srcip
    active
CSS_ACTIVE#
CSS_STANDBY# sh run
!Generated on 03/07/2010 22:31:42
configure
  ip redundancy
  arp timeout 1400
  app
  app session 10.90.1.1
interface e1
  description "TRUNK "
  trunk
  vlan 11
    default-vlan
  vlan 20
  vlan 21
interface e9
  description "REDUNDANCY - CSS-STANDY PORT 9"
  bridge vlan 23
interface Ethernet-Mgmt
  phy 10Mbits-FD
  admin-shutdown
circuit VLAN11
  ip address 10.7.10.21 255.255.255.0
circuit VLAN20
  redundancy
circuit VLAN21
  redundancy
circuit VLAN23
  ip address 10.90.1.2 255.255.255.0
    redundancy-protocol
service Web1
  active
service Web2
  active
owner KIM
  content web
    add service Web1
    add service Web2
    active
CSS_STANDBY#
If the interface e1 fails on active the redundancy is not shifting to standby.
Correct Answer by Gilles Dufour about 7 years 4 months ago
You have setup box-to-box redundancy.
This mechanism is very basic and only detects a box failure.  So, as long as the master can send heartbeat through the 'redundancy protocol' interface it will stay master.
You should use interface/vip redundancy.
A little bit more complex to configure but much more robust and with more features including interface failure detection.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/VIPRedun.html
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Mon, 03/08/2010 - 05:06
  • Cisco Employee,
Gilles.
