lms credentials
Mar 7th, 2010
Dear all,
im getting the follwing error
while i m uploading the file in Csv format
by modifying the previous one
Invalidfileformat: no Header information in the input file
Joe Clarke Mon, 03/08/2010 - 11:06
It sounds like you have modified the CSV file, and removed the header lines at the top.  The line that starts with:
Cisco Systems NM Data import, Source=DCR Export; Type=DCRCSV; Version=3.0
And the line that contains:
;HEADER: management_ip_address,host_name,domain_name,device_identity,display_name,sysObjectID,dcr_device_type,mdf_type,snmp_v2_ro_comm_string,snmp_v2_rw_comm_string,snmp_v3_user_id,snmp_v3_password,snmp_v3_auth_algorithm,snmp_v3_priv_password,snmp_v3_priv_algorithm,snmp_v3_engine_id,rxboot_mode_username,rxboot_mode_password,primary_username,primary_password,primary_enable_password,http_username,http_password,http_mode,http_port,https_port,cert_common_name,secondary_username,secondary_password,secondary_enable_password,secondary_http_username,secondary_http_password
Are mandatory for the CSV to be recognized by DCR.
avang2004 Tue, 12/28/2010 - 12:53
If you are using Excel to edit CSV's make sure to remove the extra characters in the CSV. Here is an example of a modified CSV using Microsoft Excel 2007
// Microsoft 2007 Saved file with extra padded characters (BEFORE)
; This file is generated by DCR Export utility,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Cisco Systems NM Data import, Source=DCR Export; Type=DCRCSV; Version=3.0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
;Start of section 0 - Basic Credentials,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
10.1.1.1,CoreSwitch1,test.com,,CoreSwitch1,,,,,,,,,,,,,,,,,,,,,,,,,,,
;End of CSV file,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
// You must clean up the extra characters (AFTER)
;End of CSV file
