Catalyst 3560 PoE Port ASIC Port Loopback Test Issue
Mar 8th, 2010
We have a switchports issue in this specific switch, wherein some switchports cannot be
turned on.  Whenever we try to perform a (shut/no shut) on the interface, it shows this
message:
Fa0/1 can't be brought up because it failed POST in loopback test
We also tried to 'reload' this switch, but still those switchports remains down. When we
transfer a device from a defective switchport to a working switchport, the device is working
fine.  Thus, the phsyical connection or host set-up is OK.
Here's the output from "sh post" command:
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: Failed PortMacLoopback Packet Receive asic_index 1 port_hardware_index 2
POST: Failed PortMacLoopback Packet Receive asic_index 1 port_hardware_index 3
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 2
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 3
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 4
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 5
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 10
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 11
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 12
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 13
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 18
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 19
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 20
POST: Failed PortPhiLoopback Packet Test asic_index 1 port_hardware_index 21
POST: PortASIC Port Loopback Tests : End, Status Passed
Thanks in advance for your replies.
Brgds,
Collin Clark Mon, 03/08/2010 - 07:43
  • Purple, 4500 points or more
Looks like a hardware failure and you should open a TAC case for an RMA.
Hope it helps.
