03-08-2010 02:19 AM - edited 03-19-2019 12:34 AM
Hi Everyone,
I have recently migrated CallManager 4.1 to CUCM 7.1. Everything is working fine but CUE is not able to integrate with CUCM 7.1
I have provided the new credentials for Admin User and JTAPI user in CUE 3.1 and also made a new application user in CUCM 7.1.
When I verify CallManager Admin User in CUE web interface it shows Admin login successful, JTAPI login successful.
But when I try to search and import CTI Ports from CallManager, it shows me the error IOException: No such attribute.
Can anyone please help me with this issue?
Amit.
Solved! Go to Solution.
03-08-2010 03:37 AM
See this compatibility chart:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm#CUCM
To run CM7.1, you need to be running 3.2.1 of CUE as a minimum.
Aaron
Please rate helpful posts...
03-08-2010 03:37 AM
Aaron
03-08-2010 09:01 AM
Hi aaronharrison,
Thanks alot for your reply. I will upgrade the CUE to version 3.2.1.
Thanks again..
Amit.
