QoS DSCP Analysis
Mar 8th, 2010
Hello All,
I´m trying to find a way to find how many traffic is sending my router for an interface, with each DSCP mark and identify which traffic is this (for example matching to NBAR).
Do you know a way to do this?
Ganesh Hariharan Mon, 03/08/2010 - 03:16
Hello All,
If you want to check what type of traffic is your router is sending then you need to sniff the interface and capture the packets in  a system with free available tools like etheareal and wireshark just take some sample packets to decode what type of traffic is marked with DSCP vlaue.
Hope to Help !!
Ganesh.H
mcecilia Mon, 03/08/2010 - 03:28
I´m sorry, but I do not see the way to rate your answer.
I can not use Wireshark, because it´s a remote site with no SPAN.
I was trying to find, if exists, a command like show ip nbar protocol-discovery mixed with some information about QoS.
Thanks anyway
Ganesh Hariharan Mon, 03/08/2010 - 03:35
Thanks anyway
OK !! I thought in different way anyway check out the below link hope that helps !!
http://www.cisco.com/en/US/docs/ios/12_2/qos/command/reference/qrfcmd10.html#wp1107706
Ganesh.H
