How to disable 802.11n access on guest network
Michael Murray
Level 2
Level 2
I am trying to disable 802.11n access to the guest WLAN (SSID "open"). I tried to configure the WLAN with 802.11g access only but "n" clients are still able to connect. I'm extremely green when it comes to wireless config so I'm way out of my element here. I've attached a picture of what I thought should have done the trick. Any suggestions?
Scott Fella
What you can do is go to your WLAN SSID and under the QoS feature, disable WMM.  WMM is required for 802.11N support... Test is out and hopefully that solves your issue.
-Scott
11 Replies 11
Scott Fella
-Scott
Disabling WMM, as Scott suggested, should do the trick.
Scott,
That did the trick. All the "n" connections dropped and reconnected via "g". Thanks for your help.
-mike
Glad it worked out for you.
-Scott
That solved an issue I had.
Was not able to make 802.11n working at all.
You aimed me at the right direction.
Thank you so much.
Ivan
Scott we just ran in to this and found your answer. Thank you for replay!!
That's nice to hear that others can find an older post and still use it:).
Glad it worked for you!
-Scott
Its Amazing, Thanks Scott 5+ :-)
Thanks & Regards
Vinay Sharma
Community Manager
Thanks & Regards
Thanks Vinay!!! I have seen more lately which is a good thing. I too use the search and reference older threads, but glad to see that others actually who don't really post on the forums find it useful. Now if I can get my peers to search the forum instead of emailing me, life would be good:)
-Scott
Leo Laohoo
"n" requires WPA2/AES or OPEN authentication.  So if you DON'T use the following ...
Vinay Sharma
Level 7
Level 7
Added this useful information in the document:-
https://supportforums.cisco.com/docs/DOC-18507
Thanks & Regards
