how to stop srw/sge sending 239.255.255.250.1900: UDP
smugas1975
SRW / SGE switches are sending packets like this below:
IP 172.16.57.100.1900 > 239.255.255.250.1900: UDP, length 296
IP 172.16.57.100.1900 > 239.255.255.250.1900: UDP, length 313
(a discovery message to the multicast address 239.255.255.250 on port 1900 via the UDP protocol)
Can this behaviour be disabled ?
alissitz
Level 4
Level 4
It looks like this is for uPnP.
This is normally coming from a windows machine, are you sure that it is coming from the switch?
For the switch, here is an admin guide:
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw248g4p/administration/guide/SRW224G4P-248G4P_User_Guide.pdf
These are platform specific, however you basically need to disable upnp if it is a bother to you.  It is harmless for the switch to send however if you simply want to ignore it.
HTH,
Andrew Lissitz
alissitz
Level 4
Level 4
HTH,
Andrew Lissitz
