CUCM 7.0 integration with MOC.
Mar 8th, 2010
Hello,UC
We rty to perform integration between CUCM 7.0 and MOC, the issue now that we obtain the COP file but we cant find the CUCIMOC plugin for 7.0, all CUCIMOC plugins that we found was for 7.1.X, Is CUCIMOC for 7.1.X will operate with us?
Thanks a lot......
Overall Rating: 4 (1 ratings)
Aaron Harrison Mon, 03/08/2010 - 08:09
  • Community Spotlight Award,
    Member's Choice, May 2015
Please see the release notes which list the supported versions of CCM for that software:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucimoc/7_1/english/release/cucimocReleaseNote.html#wp64340
The 7.1(3) in the title is the version of CUCIMOC, not the version of CCM that it is compatible with.
Please rate helpful posts..
htluo Mon, 03/08/2010 - 08:20
  • Red, 2250 points or more
The CUCIMOC version has no relationship with CUCM version.  ie. the CUCIMOC version could be 9.99 and work with your CUCM 7.0.2.
Michael
http://htluo.blogspot.com
m.awahed Tue, 03/09/2010 - 00:13
Thanks for all yours replies, but I have a new problem in "Client Services Framework device type" file, the problem is I cant find any link to get that file
So if any one have the link please post it,,,
Thanks a lot.
Aaron Harrison Tue, 03/09/2010 - 00:27
Now I'm confused - earlier you said you had the COP file - the COP file is the file that adds the device type.
If you don't have it, there will be a file named cucimoc-Admin-ffr.7-1-3.zip which will contain the COP file and other admin items.
Aaron
Please rate helpful posts...
AhmedBassiony Tue, 03/09/2010 - 01:00
Dear Aaron, Please dont be confused this is my fault, yestrday I thought that i have the file but i found this is a wrong file,
Any way many thanks for yours help.
