ACS 5.1.0.44.2 cumulative patch is ready on CCO
Mar 8th, 2010
2nd cumulative patch for ACS 5.1 is
available for downoad from CCO and includes fixes for the following issues:
Previously included in Patch 1
   CSCtc41730 - ACS resets SYN packets if MSS isn't set
   CSCtc20671 - ACS 5 develops filesystem issues with SAN over Fiber
   CSCtd16825 - CLI "copy" command is broken when working with "disk:"
New fixes in Patch 2:
    CSCtd10767 - Syslog data loss during upgrade
    CSCtc12382 - ACS View upgrade fails on scale configuration (improve view db performance)
    CSCtd37384 - ACS view 5.0/5.1 does not display "Remote Address"
    CSCtd54592 - Support for webAuth in ViewCollector
    CSCtd57980 - EPM Syslogs are not parsed as expected in View collector
    CSCte81150 - ACS 5.x reports key mismatch for unknown authen type
    CSCte79051 - ACS 5.1 crashing on concurrent T+ session authorization requests
    CSCte70900 - ACS 5.1 rejects AP to join WDS domain by "LEAP packet validation failed"
    CSCtd24949 - Tacacs authorization failure when authen_type=0
    CSCte16911 - ACS 5 doesn't support the PPP tacacs service type for authentication
    CSCtd99822 - AD users with expired passwords fail authentication
    CSCtd69364 - adclient fail to restart
    CSCtd00585 - ACS 5.1 adclient rebuilds the domain info map from scratch each time
