ACE 4710 in bridge mode not working
Mar 8th, 2010
I am trying to configure ACE 4710 bridge mode and I am stuck up in physical interface configuration. I have configured gig1/2 of ACE as trunk port and on layer 2 switch I have assigned that interface (gig1/2) to VLAN 11. I tried trunk port also but it got disabled due to BPDU error.
I am not able to ping servers as well as gateway. Below are the topology and context configuration:
Router   (vlan 13: IP 172.16.11.254)
ACE     (int gig1/2)
L2 Switch
Servers (vlan 11: IP 172.16.11.1 and 11.2)
Admin Context
resource-class rc1
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 0.20 maximum unlimited
boot system image:c4710ace-mz.A3_2_4.bin
interface gigabitEthernet 1/1
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/2
  switchport trunk allowed vlan 11,13
  no shutdown
interface gigabitEthernet 1/3
  shutdown
interface gigabitEthernet 1/4
  shutdown
access-list ALL line 8 extended permit ip any any
access-list everyone line 8 extended permit ip any any
access-list everyone line 16 extended permit icmp any any
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
interface vlan 1000
  ip address 172.16.16.16 255.255.255.0
  access-group input ALL
  service-policy input remote_mgmt_allow_policy
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.16.16.254
context test
  allocate-interface vlan 11
  allocate-interface vlan 13
  member rc1
test Context
access-list bpdu-fixup ethertype permit bpdu
access-list ALL line 16 extended permit icmp any any
rserver host srv1
  ip address 172.16.11.1
  inservice
rserver host srv2
  ip address 172.16.11.2
  inservice
serverfarm host srv
  rserver srv1
    inservice
  rserver srv2
    inservice
sticky ip-netmask 255.255.255.255 address both SG1
  timeout 120
  serverfarm srv
class-map type management match-any remote-mgmt
  201 match protocol snmp any
  202 match protocol ssh any
  203 match protocol icmp any
  204 match protocol http any
  205 match protocol https any
  206 match protocol xml-https any
class-map match-all slb-vip
  2 match virtual-address 172.16.11.10 any
policy-map type management first-match remote-mgmt
  class remote-mgmt
    permit
policy-map type loadbalance first-match slb
  class class-default
    sticky-serverfarm SG1
policy-map multi-match client-vips
  class slb-vip
    loadbalance vip inservice
    loadbalance policy slb
    loadbalance vip icmp-reply
interface vlan 11
  bridge-group 1
  access-group input bpdu-fixup
  access-group output ALL
  no shutdown
interface vlan 13
  bridge-group 1
  service-policy input remote-mgmt
  service-policy input client-vips
  no shutdown
interface bvi 1
  ip address 172.16.11.9 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.16.11.254
Could you pls. suggest where I am doing wrong?
Pawan
Gilles Dufour Mon, 03/08/2010 - 23:57
" I tried trunk port also but it got disabled"   <----- if your L2 config is not correct, nothing will work.
What is the setup on the switch ? Trunk or access vlan ?
What is the status of the interface ? up ? down ?
Do you see something in your arp table ?
Gilles.
winpwnkmr Tue, 03/09/2010 - 01:40
I configured that port as trunk port and it's working now after I disabled BPDUguard.
Pawan
